Hartke 350 bass hybrid bass amp combo
Selling on behalf of a friend, it's the combo version
As can be seen here:
http://c1.zzounds.com/media/fit,2018by3200/quality,85/VX3500-4187ed445201e68993558a9bf398f7d4.jpg
Proper pictures soon.
It's the rack mounted combo, specs
Product Description
Designing the Hartke VX3500 was a bit of a no-brainer. You just take Hartke's best selling head, the 3500, and mate it to the incredible sounding Hartke VX410 cabinet and Bang! Instantly you have an awesome combination of power and sound AND the best value in bass combos. Why That's because the Hartke VX3500 is NOT just a combo. It's a no-compromise way to buy the absolute best in bass equipment in one great sounding package.
The Amplifier
The 3500 mono amp delivers 350 watts into 4 ohms. It has independent tube and solid-state preamps that can be used separately or together. Comprehensive sound shaping is provided by bass and treble contour controls and a 10-band graphic EQ. It's equipped with adjustable compression to add the precise amount of sustain and presence to the overall sound.
The Cabinet
The VX 'Very Extreme' 410 bass reflex cabinet was designed for bassists who demand excellent tone but prefer traditional paper cone drivers. This warm, punchy enclosure features proprietary drivers with specially treated cones, impregnated fabric surrounds, matched convex dust caps all mounted in heavy steel frames. The high efficiency low moving mass design allows for maximum output and plenty of headroom throughout the full range of the driver. Rounding out the tone, the cabinet has a proprietary design horn loaded high frequency transducer.
Features:
- 3500 amplifier section with 350 watts of classic Hartke power at 4 ohms. 240 at 8 ohms.
- Amp section features tube and solid-state preamps, bass, treble and contour controls, 10-band graphic EQ and variable compression
- Cabinet features 4 x 10 in. tradiional paper cone drivers and a high frequency compression driver
- Solid-braced cabinet construction, recessed side handles, and heavy duty casters
- Selectable Tube & Solid-State Preamps
- Rotary Bass & Treble Contour Controls
- 10-Band Graphic EQ
- Adjustable Compression
- Balanced XLR Out
- Total Harmonic Distortion: Less Than 1% At Rated Power
- Signal-To-Noise: Approx. 78 dB
- Effects Send & Return
- Bipolar Design
- Passive/Active Input Jack
Absolute beast for gigging
Looking for £350
