I've lusted over one of these for years but was always put off because I didn't think they'd have the headroom to handle gigs, plus I worried about the lack of an fx loop for my mods and delays etc but then found myself with a 3 channel, MIDI-equipped H&K whose clean channel only got used and everything else (overdrives etc) came off my board and went in the front end.
I saw this DRRI in Guitar Guitar, tried it with my board and was blown away. It's used but mint
The cleans..well, we all know what this can do (lovely, crisp jangle and chime) and my PRS and Strat love it. I knew it took pedals really well but I wasn't expecting my overdrives to sound even better and more defined. My OCD, Keeley TS-808 and Catalinbread Formula 5F6 sounded superb and when I stacked them, even better with barely any noise. The acid test was putting an 80s rock mini-board through it (thread on this -
http://thefretboard.co.uk/discussion/28666/nhmmrpb#latest) and it's heart and soul is a Wampler Pinnacle. Jeez..it sung and took on a completely different character and the cabinet has some oomph and bottom end to it. Sorry to use this word again, but the sound was so
defined and it's like someone's taken a blanket off of my pedalboard and the H&K clean channel was no slouch.
I hope I've got an "amp for life and as to the potential headroom issue, I'm not bothered and I'll mic up if it can't be heard or breaks up too early, but it sounds plenty loud for the functions and gigs I do! I even plugged my Taylor acoustic into one of the channels and it wasn't half bad. I still need to muck about with the input channels and see which one I prefer.
Sadly, there wasn't a Rev/Trem footswitch with it so I'm on the hunt for one of those.
EDIT: I've now got a proper footswitch for it and a red jewel light (my one had its one changed to bright sky blue and I didn't like it at all)
You can also use this trick as a pseudo-parallel FX loop if you're getting most or all of the dirt from pedals. Do the same as above but go from Normal channel input 2 to the FX, then back to the Vibrato channel. Essentially it becomes a wet/dry rig in one box. If you're feeding the Vibrato channel with a pure wet signal the volume setting doesn't matter either.
If you can't get the right footswitch, any plain two-button latching switch with a stereo plug will work on the reissues since they don't have the dual-phono arrangement of the originals. The ones that won't work are any with LEDs, including the Fender ones from the red-knob/Hotrod/etc series.
Someone on here also mentioned about putting the drives through one channel and the mods/delays through a different one.
And that if you're jumpering the channels to make a pedal that sounds buzzy though the Vibrato channel work, set the Vibrato channel treble low or off. The reverb doesn't need it.
I have it set up with the gain on 9-10 o'clcock and I don't like it beyond 12 o'clock as you get that gnarly Neil Young sound but it's "crazy" horses for courses and if that's your thing, it does it. I can get that Tom Petty "clean with hair" sound, some crunchy Bryan Adams sounds with humbuckers and some really good funk sounds with single coils. It also seems to stack well with other overdrives.
Another thing about the pedal is that it has an internal switch and when engaged, the character of the pedal becomes more plexi and higher gain. It sounded good through my H&K but through a Fender...it's absolutely wonderful. If you can get to try one, I would.
Not only are the 'Blackface' cosmetics the smartest any amp has ever carried - there is something about the proportions of a Deluxe Reverb that look great too.
I want your amp. Fact....
My mate in the US is already sending me suggestions for speaker, transformer and baffle board upgrades!!! If it ain't broke.....
My music:- https://soundcloud.com/hubobulous
