If its not in as-new condition, always check for missing or damaged castors and the wood around them - they can take a severe battering if the cab has been gigged - and any damage to the input/switching panel, which can get stressed if the cable is tugged sideways and in the worst case can be a risk to the amp if it fails.
@ICBM, you're right about not wanting to travel to far to collect, especially when I've seen a B-stock at £450 delivered.
Thank you all for the advice. I thought I may have be being a bit tight, but you've reinforced my convictions.
Or do I?
Unless you're holding out for purple. That would be acceptable.
he was the first person I sent it to. I quite fancy myself with absolutely no need for it.
