Hi All, I have a small studio set up in my back bedroom / man cave. PC , presonus studio one, presonus USB interface with 2 versatile inputs, presonus condensor Mic, Vox AC30, Gibson SG, tc nova system, cheap bass amp, cheap bass, Roland td3 drums, technics amp, mission speakers.
For someone messing about on his own it's perfect and I'm happy with the results but I want to record 4 tracks simultaneously with my band whilst rehearsing. I can't get the hang of the midi drum thing so I'm just using audio out.
My question is this. What's the easiest and cheapest way to record 4 live tracks starting with the equipment I've got.
Buying a 4 input interface?
Is there a mixer that does that instead?
Mic up guitar and bass splitting with DI boxes, drums straight in, vocals later?
Guitar and bass through DI boxes then straight into the interface along with drums, vocals later?
Any advise would be appreciated.
Thanks
Phil
The Native Instruments Komplete Audio 6 has 2 excellent mic inputs and two further line inputs so that would give you 4 tracks but I don't thinks that copes with all the gear you have?
One solution would be the KA6 plus a small mixer to give 2 more mic inputs plus line ins (for drums etc) These mixer sources would be "panned" into the second pair of tracks..Not ideal but workable.
But! Tascam have a new model out that replaces the excellent US1800 so the latter is being heavily discounted atmo'. 8 mic inputs and GAKs how many line ins, the 1800 fairly bristles with connectivity!
Of course you will have to build up the extra mic/stand/cable stock over time
https://twitter.com/spark240
Reddit r/newmusicreview
This would give you the flexability to record anywhere and bring the recordings back to your studio to mix/work on.
[/quote]
The drums were unresponsive and suffering from some lag. I am more than happy with the Roland drum sounds so line out or audio out is perfect for me. Also the simpler the better, we only have limited practise time and I want everything to work first time every time. Not my experience of midi.
Just looked at the R8 and it only seems to record 2 tracks at a time. The H6 seems a bit more flexable and is considerably smaller/more portable.
I do something similar with an improvised ambient project I have. We record live onto an old Yamaha AW4416 (which is a little archaic in digital technology terms but is a reliable 16-track-at-once recorder) and then transfer the tracks to computer for mixing.
I have some kit and use it in a limited way but I'm a novice when it comes to any recording. I realise I have to use DI boxes to split the instrument signals between the amps and recording device. Would you Mic up the amps or go straight into the interface?
There are three places you could take a DI feed from ...
1) After the guitar effects, before the amp input. Obviously, this would not have any eq or drive provided by the amp.
2) From the amp's 'line out' (assumining it has one). This would give you the amp's pre-amp tone. Some amps have a 'speaker emulated' DI out which is ideal for an easy life.
3) Between the amp's speaker out and the speaker. Obviously, the speaker connection can't be hard wired for this to be an option. You would need a DI box designed to accept a speaker level signal (H&K Red Box or Behringer GI100 can both be used like this). I suspect, at low volume levels on the amps, this method may prove to have quite high background noise.
I suspect, depending on what amps you're using, methods 1 or 2 will have the most hassle-free setup.
With my project, I'm using the amp clean at very low volume. I tap off a DI after my effects boards (in the fx loop after the amp's pre-amp) using either an Award-Session MB10 or JD-10 (which both have speaker emulation) and add a little eq and reverb on the mix.
Been a VERY long time ago but I do recall that practice time went past in a flash with far more **ing about than music done? Especially on licensed premises!
If you need to rig several mics/DIs/cables and setup a recording system YOU better get there 2 hours before the rest of the band!
HNY to all.
Dave.
On a different note, the after some experimentation the guitar through a DI box sounds a million times better than straight into the Hiz inputs on the interface. Also plugging the guitar straight into the presonus gives a much better sound than straight into the tascam. Through the DI they both sound the same.
Hope this post helps someone
Phil
