It's pretty much everything the demos shows and actually lives up to its advertising blurb. I know that doesn't help the GAS but it really is that good.
Clean channel can do fender like cleans (there is a bright/dark switch), 80's mode in modern setting has plenty of gain for heavy stuff. 70's moden in Vintage can do Plexi like tones. The FX loop is actually very good in this as well or if you choose to put all your pedals in front, no problems there too.
There are other little things too that I love, the front of the amp lights up for only the knobs that is in the circuit. So when you are using the clean channel, only the knobs that works in the clean channel will work. Which I can imagine is quite useful if you play in a dark stage. There are 4, 8 and 16ohm speaker output so you have plenty of choices for speakers. There is also a Line out too but I have not tried that, I don't think that is loaded though so you still need to plug in a speaker. Because of the all metal casing, you can use it as a little heater in the winter, win win !
But nothing in this world is perfect and I'll be truthful about that : -
The footswitch is a little counter intuitive with the on/off solo channel. It is opposite of what you think it is.
The EQ knobs (Bass, Mid and Treble) only works on Crunch and Solo channel, not Clean, which it has it's own dedicated Tone control knob. Some users found the clean channel a bit too bass heavy on their set up, some solved it with an EQ pedal, some by switching speaker cabs. The recommended speaker for this amp is a G12H30 open back cab. I have a V30 Bogner Cube.
But apart from that, I absolutely love the little thing. It is well made, a little different looking that i love, light, very well built.
Thanks @Hymnal !
Another thing I forgot to say, which is a pretty important and what drew me to this amp in the first place. The 18/5/1 watt attenuator switch.
It works brilliantly in this. Even in 1 Watt mode is actually pretty loud, the online Youtube videos doesn't show you that, some of the Youtube online vids makes it sound compressed with no oomph yet the users are saying it sounds great. In reality it sounds great full stop. There is plenty of headroom in all the power modes. It is deafeningly loud at 18W, I have not compared to another 18W or 20W side by side but this is so loud at 18W I never use that at home. Mostly is 1W, 5W the most.
So this is Clean Channel, Just Volume and Tone knob lit up.
Tone on the left, Volume on the right.
There are 3 Volume knobs so you can set each channel to set volume, very handy for Solo. There is a separate Gain knob for Crunch channel on the back.
lol, that is quite expensive! Why not just get the Goldfinger 2x12 cab?
My music:- https://soundcloud.com/hubobulous
