Nil Satis Nisi Optimum
I'm currently losing weight to see if that helps, though tbh my missus has the ears of a bat, so I doubt it'll make any difference.
I snore like a bitch. To the point of waking myself. Sleeping on my back helps loads. I don't suppose severla broken noses helped.
A friend had to have a small operation on his nose (I'm not entirely sure what was done) but apparantly that has helped his snoring.
Overweight doesn't help. Alcohol makes it worse. Dehydration makes it worse.
I use Breathe-Right adhesive strips at night. My missus says snoring is much reduced when I stick one of these across my nose. You can buy them on Amazon.
If you take Drew's advice you could sign up here -
https://groups.yahoo.com/neo/groups/snoringfetishclub/conversations/messages/410
Thing is i was wide awake just lying there.
I dont think i snore so i'm disputing it.
Tried lots of things and this device really worked for her. Not cheap though
http://m.boots.com/mt/www.boots.com/en/Snoreeze-Snoring-Relief-Oral-Device_1285293/#un_jtt_addtohome_hidden
you sing UNG-GAR
thats UNG as in HUNG, and GAR as in GARDEN
sing them very firmly, you can feel something happening
i cant remember now, but something along the lines of 30mins a day for a couple of weeks, then 5-10mins a day after that maybe?
