hello, I work for Source Audio and wanted to jump in to help answer any questions:
About the Reflex Expression Pedal:
*The Reflex has 128 internal presets ?
Correct. These are stored in its own memory. Even without a MIDI controller or Hub, you can recall presets using the simple menu interface on the Reflex control panel.
*The Presets can be recalled with PC messages from the Hub ?
Presets can be recalled with PC messages from a MIDI controller. The Hub is able to do a MIDI Thru function so that would work as well for getting MIDI from a controller through the Hub and to the Reflex.
*Will it show up in the Hub Manager?
This is planned, but currently in development.
