powering a fuzz....
bigdawgbigdawg Frets: 51
fed up with keep running batteries out so looking to go the diago route.
Am I right in thinking that a diago positive ground adaptor matched with a one of these:
will power it ok..??
  • Possibly. Depends on the fuzz. This is the best thing out there.
    http://www.thegigrig.com/acatalog/Virtual-Battery-VB-BC.html#SID=24
  • It depends if the fuzz is actually centre positive.  Just because it is positive ground doesn't mean the plug is centre positive and in fact the vast majority of more modern fuzz builds (DAM, Fulltone etc) are positive ground but still with negative centre so you'll need to check first.
  • bigdawgbigdawg Frets: 51
     its a fulltone 69
  • The 69 is centre positive I believe so yes you'll need one of those leads too.
    thank you - Im assuming then that the big black one is firstthen the red attaches to the pedal?
  • JD50JD50 Frets: 662
  • xHymnalxHymnal Frets: 255
    I know it's a pita but batteries really are the best way for fuzzes imo. They sound better than consistent power from a PSU and avoid all issues of polarity screwing up your fuzzes
