It's a VH100R
Tried using my Laney yesterday and all I could get out of it was a very quiet, weak, slightly distorted tone.
I tried all the channels and got the same sound at all levels.
It was working perfectly 2 weeks ago, then I returned back to work, where I leave it set up and it's not working.
I've tried various settings on the FX loop, and fiddled with the level knob on the back, as I know this can act as a sort of master volume in certain applications.
All the power valves are glowing as normal. I think perhaps it might be a preamp valve.
Any ideas?
Check your speaker cable too. If you don't have a spare one a guitar lead will do to test it for a short time at low-ish volume.
If the signal from the FX loops is very quiet it may just be that the loops are at a high signal level and the guitar is too low - that would probably also explain the lack of distortion. Or it could be related if both are caused by the fault - the most likely culprit would be the phase inverter valve, usually the one nearest the power valves. Try changing that first.
