Hi all.
I've ordered JCA20HV from Thomann last Friday, finally arrived today and I've just had a go on it, unfortunately due to late hour I had to keep the volumes fairly low. But even so - so far so good.
First impressions:
Build quality is very nice, I don't see any flaws, loose screws, rattling cab parts etc - I don't own any other Jet City amp but I've read that they are well made - that seem to be the case here as well. Quite lightweight, tidy built. No extra eyecandy with the amp, just the head and some manuals. For that price I wouldn't expect anything else.
I've grabbed UK kettle lead and set the amp with b/m/t on 4ish and presence off. Started with volume halfway and gain set at 2.
Tele with AV 52/58 single coils first.
Amp has a pleasant warm tone and starts from nice clean tone, breaking up quite quickly though will have to check that at higher volumes. With gain past 3 we have tweedy overdriven sound and we enter crunch territory around 6-7. Sounds full, with good bottom end and with presence up and treble full on guitar didn't sound harsh which I've read could be an issue with JCA22H.
I used Line6 DT112 cab with Celestion G12H-90 - it's my go to cab and sounds very good. Amp sounded great with other guitars with humbuckers - tested with LP, Jaden and Charvel. Cleans up when backing the volume on guitar even with high output ceramic pickups.
At the moment I'm really happy with it - though it's just my first impression and bear in mind that it's been tested at medium volume levels only. Amp is quite noisy with 'gain' set anything above 2,5 but I would expect some cheap-ass valves inside so will have to check that once replaced. I will try to record some vids or samples but won't happen this week as I'm barely at home. Thanks for reading.
Be interesting to see what you think when you can turn it up and how much difference new valves makes.
But the blue-fronted ones suit what I play better (i assume, anyway).
Amp is loud. To play it at home I keep gain up halfway, (down to 2-3 if I want cleans) and volume around 1 Amp is very alive at this levels though and quite loud too. Doesn't really do Fender-type cleans of course, but I like a little hairy" bluesy cleans. With OD pedal it's full on rock amp, I'm waiting for my Lovepedal hi volt to see how well it does hi gain sounds.
No issues with fx loop, reverb, delays, they sound very good.
It's a sweet amp for that price (for any price really) and I must say that I'm surprised with build quality and tone in that price range. I think Jet City would be more popular if they were twice the price Somehow they aren't being considered as a pro amps while they're better than i.e. Marshalls for nearly a grand I've tried last time.
Well recommended anyway!
Zip it, willya?
@not_the_dj - I'm using TC electronic pedals, flashback and HoF verb. They apparently DO work well with JCAs but I've used both pedals for ages, so cannot speak for how the other ones would work. But I think in 20HV they sorted issue with fx loop anyway.
