Nil Satis Nisi Optimum
Removing the dust cap requires patients and a steady hand with a razor blade to cut/separate the cap from the cone before glueing the new one on.
Before you try that, have you verified that the cone and coil are not at fault? Spread your hand/finger tips over the front of the cone and gently push it in. (quite room required) You might here grating as the coil touches the sides of the magnet groove. In this case nothing but a full re-cone or replacement speaker will get rid of the buzz and further use will eventually lead to total failure as the coil wears through.
