Wonkey Indicators
monquixotemonquixote Frets: 17702
in Off Topic tFB Trader
The indicators on my car (2003 Audi A6) have gone a bit wonky
They seem to flash a few times then stop so I'm assuming that the relay is busted.
Anyone worldly wise able to suggest how big a job it is to get it fixed?
  • lloydlloyd Frets: 5774
    I fixed my mates headlamp last week by hitting it with the palm of my hand a few times-have you tried that?
    Manchester based original indie band Random White:
    https://www.facebook.com/RandomWhite
    https://twitter.com/randomwhite1
  • monquixotemonquixote Frets: 17702
    Funnily enough I've just scouted a couple of Audi forums who have said the relay is behind the hazard switch and giving it a good beating sometimes clears it up.
  • TTonyTTony Frets: 27736
    Can't really see how hitting your mate's headlamp is going to fix MonQ's indicators ...
    I'm no mechanic but it's worth a shot in my opinion.
  • FX_MunkeeFX_Munkee Frets: 2483
    edited January 2015
    Find where the relay is (under bonnet fusebox or interior fusebox). There's probably a few relays the same in the same location.
    Swap for something trivial e.g horn.
    Test.
    Relay should be about £15 to replace. Unless Audi have "special" ones.
    Edit: I just googlefoo'd this and they are "special" </sigh> so you can safely ignore this advice.
    Shot through the heart, and you’re to blame, you give love a bad name. Not to mention archery tuition.
  • ESchapESchap Frets: 1428
    automotive transference ...
  • GassageGassage Frets: 30988
    Sounds like an intermittant earthing rather than a relay
  • mike_lmike_l Frets: 5700
    Is it the same on both sides? And VW/Audi hazard switches (actually all hazard switches) can easily go bad.
    Probably worth a good squirt of contact cleaner into the switch as well.
  • axisusaxisus Frets: 28347
    It's a deterrent. When his car sees another car getting beaten up it gets its act together.
    I've just been out and banged the dash and amusingly it does make the indicators flash a couple more times before stopping.
    Supposedly the part is about £20, but fitting it requires partially dismantling the dashboard. I'll have to give my local emporium a shout and see if they can do it.
    letting off firearms at it is a bit drastic
    I was thinking of whisky (but don't drink and drive kids)
    How about just leaving the lights on and winking with either your left or right eye depending on which direction you're turning?
  • Paul_CPaul_C Frets: 7860
    2reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • ICBMICBM Frets: 72740
    On an Audi? How did you notice?
    The irony of driving an Audi with non functional indicators is not lost on me :)
    Oh how did I miss that. I feel so foolish. Just like that time those people said they were bottom inspectors...
  • VimFuegoVimFuego Frets: 15657
    just to check, when you say wonky are they on, then off, then on, then off, then on, then off etc. in rapid succession?
  • shugzshugz Frets: 768
    edited January 2015
    All jokage aside, this is definitely the relay behind the warning lights. Its a known VA Group issue and a relatively easy fix. Just change out the relay if you can as it will come back to haunt if you don't (t shirt bought there).
    Look for anywhere local that services Skoda taxis, it's the same part and probably about 80% cheaper than main dealer.
    Cheers
    Hugh
    www.proudhoney.com
  • Does it happen with the hazard lights too? I would guess they share the same relay.
