Time to have a look under the 'plate.
http://img.photobucket.com/albums/v375/Niallmo/FAF3358A-F9E0-4964-9CAA-C732A1669F82_zpskowr3cpe.jpg
Generic Single coils. Lots of wires, the ATN circuit and only a little fading of the colour.
It looks like it's a sandwich body. Definite line in the routs about halfway down. It's also had the middle tone pot replaced with a full size 250k instead of a mini.
http://img.photobucket.com/albums/v375/Niallmo/F9616FDB-71E0-4A26-B82F-B8CA8ACD0FB0_zpsxkqektkm.jpg
At this point I want to get it playing so I'm leaving the wiring. I know it's wrong as the volume is acting as a tone!
Anyway. Give it another go with flash wipes, making sure to do the edges of the scratch plate. Strip the tuners out of the headstock and flash wipe it. Get the Pledge out and polish the body and neck. Check the hardware...everything looks ok. Give it a quick wipe and polish. Don't want it looking too bright and new!
Put everything back together....
http://img.photobucket.com/albums/v375/Niallmo/0B58D85B-E067-4644-9C07-BC63331BB52F_zpsyvc080ry.jpg
Now it needs strings and a set up which hopefully I can get done later tonight.
That lot took about two hours to take apart, clean and put back together. Essential in older and manky guitars and easily doable with a decent screwdriver or two and household cleaning materials!
Neck gap on arrival with a small paint crack.
http://img.photobucket.com/albums/v375/Niallmo/7116915B-0AAA-4F4A-B0B6-18F0D1A07613_zpsghtrtgvp.jpg
Different view of the complex wiring.
http://img.photobucket.com/albums/v375/Niallmo/04C426D1-C955-4292-B885-BABDF9E07D6C_zpstqtpktvz.jpg
Corroded pots, I guess the middle one failed to completely and was replaced.
http://img.photobucket.com/albums/v375/Niallmo/EFEBCAE2-4B59-436A-88B8-A13B8314B752_zpsq7edgabb.jpg
It's quite heavy, big body! Now it's cleaned it looks like a very honest, well played guitar. Ageing nicely.
I've now got strings on it, looks like a replacement nut but seems well cut.
http://img.photobucket.com/albums/v375/Niallmo/38D1A2F8-A813-44A3-A3C8-41BA2114FB78_zpsobdhfb7y.jpg
I've used the micro-tilt to shim it a little to get some angle on the bridge saddles.
http://img.photobucket.com/albums/v375/Niallmo/2DDA42AB-83DA-4F95-9774-202435F6A0B9_zpsg59hhmsl.jpg
http://img.photobucket.com/albums/v375/Niallmo/DF91C331-CFED-4EDA-B4B0-32B995361095_zpswuz41mmv.jpg
Now comes the fiddly part of setting the trem, string heights.
Do let us know about the electrics, I've heard of that ATN circuit, but not too sure what it is.
Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
Trading feedback: Previous (+18) and Current
