SOLD: Bad Cat Classic Cat 20w Combo
I am selling this with some regret, as it's now surplus to requirements.
2006
20w
6v6 JJ Output valves
GZ34 Rectifer
Like a Fender '57 Deluxe on Steroids!
Definitely the best-sounding amp I've ever owned. Just two controls: volume and tone - nothing else to muddy up the signal path. The idea of this amp is that you put the volume on full and control the volume from your guitar. Bliss. It takes pedals brilliantly as well.If you're looking at this you probably know all about these amps, but if not, a Google search will turn up plenty of material.The amp has been re-valved recently so its ready to go. Since then, I've used it in two or three rehearsals and one gig, so nothing needs doing to it.As you can see from the photos, there are some small scuffs and tears in the vinyl, but nothing disfiguring - the photos make them look a lot worse than they actually appear in the flesh. There's a bespoke cover which protects it nicely against any further scuffs.
