Spend my GAS tokens
Flanging_FredFlanging_Fred Frets: 3021
So I find myself with €50 of Thomann vouchers I need to spend before they run out. I don't really need anything as such so I'm not to sure what to spend them on. I can add a little bit of cash on top, but not much. So what should I get?
Ideas so far are a Boss SD1 (should go well with my JCM800) , EHX soul food (just because of the hype really), a pedaltrain Nano or perhaps a DiMarzio Tone Zone pickup to stick in the bridge of my Hondo strat.
I'm finding it curiously hard to decide on a freebie like this. Hit me up with cool ideas.
P.s. first person to say 'give it to me' gets a boot in the nads.
  • The SD-1 will go brilliantly with the JCM800.
    DO IT.
  • d8md8m Frets: 2434
    Give it to me.
    Here you go:
  • Dave_McDave_Mc Frets: 2358
    DO IT.
    +1
    soul food is nice too, but yeah if you want a boost the sd1 is where it's at with marshally amps I think.
  • ab2014ab2014 Frets: 89
    If you can and need stuff i'd order to the $200 limit to get the free delivery
  • I got an SD-1 before Xmas and it's brilliant.
    It'll turn a crunchy jcm800 into a fire breathing, harmonic screaming demon beast of an amp.
  • You could always just stock up on strings and picks but that would be boring.
  • or you could spend a little bit of money on top and get a RAT for 56 quids
  • Looks like an SD1 might win the race. I was also thinking about a rat or a Mooer Black secret but Im pretty sorted for distortion pedals (always room for another though at some point). A TS-ish OD is higher priority since I got rid of my Bad Monkey ages ago.
  • mike_lmike_l Frets: 5700
    SD-1 or Bad monkey, both work awesomely with Marshall amps.
    I'd take SD-1 first, seems to work well with any* amp.
    *Defined as the ones I've tried.....
  • koss59koss59 Frets: 847
    How about trying a clear sonic baffle so you can crank your 800 more?
    I've always wanted to try one.
    Facebook.com/nashvillesounduk/
  • koss59;505719" said:
    How about trying a clear sonic baffle so you can crank your 800 more?I've always wanted to try one.
    That's sounds like a first step on the slippery slope of trying to be Joe Bonawotsisname (and failing). Not an odesey I wish to embark on.
  • The Maxon 808's were quite cheap on there, i dont know if they are any good mond!
    ^ Apparently they're shoddily built.Never tried one myself.
  • I have a maxon (od9 mind) and it is wonderful.
    Thomann has a pretty good price on the VS Route 808. Not to enable your GAS or anything.
  • BeexterBeexter Frets: 599
    Can't go wrong with an SD-1. It's a classic.
  • Well I got the SD-1. Now I know why Zakk Wylde spends his whole life doing pinch harmonics. It's pretty hard to stop it from screaming like a guinea pig with hot poker up it's 'arris. Loads of fun.
