Lol, if I find anything I'll post it here in case anyone else gets DrumPerfect.
electric proddy probe machine
My trading feedback thread
What I will say, though, is that I'm using an old version of Addictive Drums which is very user friendly. You can run it as a stand alone 'drum machine' style device or as a VST instrument triggered by a sequencer (Cubase SX in my case). Included with it are quite a few drum grooves, fills, etc in a selection of styles (which you can either play drum machine style or drag into your sequencer as a midi pattern.
Various midi drum patterns can be found on the net for free which can be used to trigger the AD drum sounds.
If I'm just noodling with AD I'll just start up one of the preset patterns, select a kit I like the sound of and maybe tweak the sound in the mix (I get a lot of mileage out of just tweaking the 'overheads' and 'room sound' levels without any deep fiddly editing). The kit is laid out like a normal mixer with faders for levels - all very intuitive. Sounds pretty natural, too.
So, if you find Drum Perfect a bit too fiddly/complicated maybe check out Addictive Drums if there is an iPad version.
I'll bear that in mind when I move across to Ableton Live mate, thanks for the heads up.
