Rigggght.....OK.......
I hate plastic Chilli and the gripfill will take half the plaster away with it. I spent an age levelling prior to fitting the skirting and I like the clean look of the perfect skirting. Only the wires detract for it and are hard to vacuum around.
I think I'II run a few runs under the bare floorboard, along the joist, drawn with wire through the insulation to some sockets. In my search for anal perfection, maybe a floor socket wouldn't be a bad idea, which can be replaced with a drop in floorboard or something, should I wish to reconfigure the furniture. But think I'II put the angle driver on the end of the drill what I use for drilling out inaccessible spot welds and go through a socket cavity in a partition, behind the skirting. It will be cheaper than getting some trailing lead rubber hollow stuff. I've just remembered, I do have a ring mains socket neared the hi fi too.
Nil Satis Nisi Optimum
