FS: 70's Selmer Treble & Bass. £250 including tonebones for 8w or 50w
In reasonably good condition. When I first got it it had some crackle but this seems to have disappeared as its been used. I have fitted tonebones (triode) which reduce it down to 8w from EL84's, but the EL34's are still here so can be put back in without any biasing required to take it back up to 50w
still very loud at 8w and takes pedals well, but you won't get a lot of distortion at home volumes from the amp alone
the light on the standby switch doesn't work, the knobs could do with repainting and the aluminium shield around the power valves has been bent back to make room for the tonebones.
I am after £250 collected - including tonebones, 2xel84 and 2xel34
Located in Burton On Trent
Instagram
Instagram
Instagram
Bump
Instagram
