Got a Gear4music Telecaster kit for Christmas and finally got round to putting it together.It wasn't a bad kit but it does need quite a bit if work to make it an ok instrument.The neck needs a bit of work on the frets and needs a finish putting on it which I basically can't be arsed to do at the minute so I've used a CH Guitars neck I had laying around instead.I know the headstock will split opinion but it's such a comfortable neck with lovely frets and rolled fingerboard edges and feels quite similar to my Charvel San Dimas,I just had to use it.I'll probably sort the supplied neck at a later date.I just need to add a thin piece of veneer on the treble side of the neck pocket to fill a small gap.
I wired it and stringed it up yesterday and this threw up few problems.Firstly,horrendous buzzing which was soon rectified when I realised I'd wired the jack socket the wrong way round.Then there's no output from the neck pickup which I think may be a switch problem as there is also no output from the bridge pickup when in the middle position.The electrics will be getting replaced with an Axesrus wiring loom when I have the funds.
On stringing it I noticed the string spacing at the bridge is all over the place but as I intend to replace the saddles with brass ones this should be easily rectified.
Lastly the tuners are complete bobbins so they'll be getting replaced at some point.
The body is really nice and came up lovely with a couple of coats of brown furniture wax.
All the hardware except the tuners have been lightly aged as to me it looked wrong all shiny and new.
Laugh, love, live, learn.
Here's another.
I'll probably be looking at changing the hardware,pickups and electrics at a later date so I'll check out the gear you mentioned.
Thanks.
