After considering for a while just using my Zoom G3 for everything FX-wise, it's now looking like I will be having a small pedal board after all - at least for home use. I just received a Zendrive clone (a Big Knob Zed Drive, bought on this very forum from
@randomhandclaps, cheers mate) and having had a chance to test it, I do really like the sounds I'm getting from it - always thought I would, based on the Zendrive demos I've seen, and nice that it seems to work out for me in practice.
So - it's going to be the Zed Drive going into the G3 - which will provide all the modulation/delay/reverb, going into my Digitech JamMan Solo XT looper. I'm thinking I might want to use a bit of compression with the Zed Drive at times, so I'm thinking the G3 can do that as well... But is it usual/OK to have the compression after an overdrive pedal? Also, is there any downside to the compressor models on the G3, compared to a "real" analogue compressor pedal?
Cheers for any help or advice, thanks!
i've tried the comps on the G3 before as i was trying to set it up as my 2nd board...have to admit i didnt like them at all. I also like having comp before Dirt, so the solution was to use the zoom dirt, and that with the comps was horrible and noisy.
you may find it to be ok since your using another pedal for dirt, but im not a fan of comp post dirt, i think it kills the character and rawness of the dirt pedal.
I recognise that there are benefits of putting compressor before drive, I.e. You get a very even, sustained drive sound. And of course, some people use boost pedals to push drive pedals (as opposed to using your volume knob), so a compressor before wouldn't affect the responsiveness of the drive pedal (responding to your volume knob).
The downside to compressor after drive is it increases noise since it would boost the noise coming from a drive pedal. My drive pedal and compressor don't produce any noticeable unwanted noise, but then again, that's partly because I don't use very much gain.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
I bought one off the back of a recommendation to replace my Behringer CS400, for £25 you can't go wrong and it might allow you a bit more flexibility.
EDIT: It only arrived yesterday so I've not been able to try it out. I'll give you a review tonight when I've plugged it in.
electric proddy probe machine
My trading feedback thread
Did you see guitar that's arriving at mine in a few days for the forum modding challenge?
Lol.
The only thing I don't want it to be is a very noticeable finish blemish on the top as I don't intend to refinish it, anything to do with set up will be taken care of as part of the process.
The only downside to digital compression instead of analogue is that it can sound a bit different. You'll get mixed reviews of the G3 compressors, personally I think they're ok, others hate them.
Try it and see, if it sounds right to you that's all that matters.
