My Jet City JCA50H arrived today, and here are my first impressions. Please bear in mind that I'm just not that knowledgeable about amps and don't have much to compare it to though...
I'm running it through a virtually unused JC12S+ 1x12 cab. I don't know how different it'll sound when the speaker's been played in a bit, and ideally I'd have a 2x12 anyway (I got the cab before the amp and only recently decided to get the 50w) but as I've had a bit of a GAS-fest recently I need to offload some stuff and let the Mrs calm down before I can even consider it...
![:D :D](/plugins/EmojiExtender/emoji/fb/4.gif)
The crunch channel will give decent cleans at home level (and just a bit beyond that too - sorry, next door neighbours!) with the gain kept very low, although it's a bit quicker to crunch with a higher output pup. I've only tried it with my Epi 339 so far, I suspect my Schecter will be a bit harder to keep clean. I was able to dial in a very rich, clear clean using the neck pup and playing with the eq, but the overdrive channel gain knob needs to be all the way off or it seems to influence the tone. Is this a normal thing?
Turn the crunch channel gain up a bit and it, well, crunches up lovely. At about 12 o'clock it was getting close to AC/DC type loveliness, or as close as I'll get with my guitars and fingers. I don't know how to describe it with the gain further round the clock except to say it gets crunchier
![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
The overdrive channel has gain to spare, that's for sure. I didn't play with it too much, but it's something I'll be experimenting with over the coming days.
I tried some pedals though it too, my klone and Rat sounded good, but again, I need to play with it more to get the best from them.
I put my Slicer and M5 through the loop, and there was a noticeable volume drop when I engaged the M5 with a tape echo model. I don't know if this is something to do with the pedal, and I didn't see any way to adjust the level for that model so I'm a bit confused about this. The Slicer was fine though.
It was supplied with a non-original footswitch as they didn't have the correct one in stock but they'll send me one when they do. The one they sent has a jack on it and they chucked in a Soldano branded cable so I've probably done well there having read other people's complaints about the standard, hard-wired one.
Both master volumes work very well indeed - so well, in fact, that if it had an emulated out that I could plug into my Focusrite iTrack I wouldn't actually need the HT5 stack I've just bought second hand... Still, at least I'll be able to try some of the stereo settings on the Slicer and M5 and I like the Blackstar too so it's all good!
I think I've heard that about the OD channel bleeding into the normal channel. I haven't really noticed that myself, but then I haven't really been looking, and I play 99% of the time on the OD channel
The loop's line level so that might be affecting the M5.
electric proddy probe machine
My trading feedback thread
I now understand that Ditto looper question - at least that will handle the line level ok.
http://www.jetcityamplificationstore.co.uk/product/jca50h/
