Please give me the benefit of your experience, your buying mistakes.
It's easy to find an option for a way to record guitar and turn it into a song. But there are that many interfaces on numerous platforms that it's a bit overwhelming, and I don't want to be a buy-cheap, buy-twice novice.
I have a good PC running windows 7. I have a decent amp, a decent guitar and a few pedals, plus a keyboard.
I've considered buying a Mac, and would seriously consider that if it's the way to go. But given that sort of budget, I imagine the options for something to use with my Windows PC are fairly good. I'd like to be able to record vocals too.
Replaced by the Roland Octa range now.
From my experience the Edirol/Roland drivers on a PC Win XP/7 are very stable. I use asio4all in Ableton resulting in very low latency: 32 samples 4ms. As long as your PC has good latency your interface of choice should be fine. Use a DPC latency checker to test your system.
MR round-up of interfaces
https://twitter.com/spark240
Reddit r/newmusicreview
You don't need a mac, even a modest "office" win 7 PC will cope with everything you are likely to do for a long time. "Modest" like this HP i3 I type on is MORE than capable.
Just my take on the situation but a Native Instruments Komplete Audio 6 interface will be as good as anything you will get for around £160 or in fact a lot more.
It has two excellent mic pre amps which double as line inputs and high impedance guitar inputs. Has two more balanced line inputs (4 tracks in total) plus digital in and out and MIDI I/o. The KA6 comes with a cut down but nonetheless very powerful version of Cubase, no better recording software for MIDI. What is the make and model of the keyboard?
Microphones? I would suggest two (matched pair if you can) Small Diaphragm Capacitors (aka condenser) just about the most versatile mic type there is. Ideal for acoustic guitar.
You WILL need monitors but maybe not just yet. Headphones are fine but try to play stuff through a "hi fi", in the car etc.
You might like to look two other forums. Home Recording and Sound on Sound.
Dave.
Ooo! that looks like a very fit keyboard!http://www.soundonsound.com/sos/mar05/articles/rolandjunod.htm
You will be able to hook it up to the KA6 with DIN leads and have all sorts of fun! The AI comes with Kontakt Player and about 3G of sounds to download. The stereo output of the Juno will conveniently feed the two line inputs 3&4 should you get the KA6. The keys could in effect become an pretty good drum machine and a lot more beside.
The red spike could be a wireless function having a "looky see". Another possibility is Windows sounds, bleeps and bloops and you might have to disable the internal soundcard when you get a proper interface.
Dave.
Add a decent mic and/or DI and you're in business
World's your oyster then for recording software.
- Reaper is superb and stupidly cheap (and fully 64bit).
- Tracktion is back, also inexpensive, also superb
- Cakewalk, Sonar, even ProTools all run on PCs
- and for noises/loops Reason & Ableton run on PCs
Feedback
I prefer Roland/Edirol units for driver stability & build quality/shelf life - so no regrets. Though there are lot's of good units now from Focusrite, NI, Presonus all similar in spec.
My YouTube Channel
Look at a Steinberg UR22 or UR44. I have both on Win 7 machines. Rock solid drivers and excellent Yamaha technology [Yamaha basicially designed these units] .. the mic pres are excellent. If you can run to the UR44 the unit comes with some excellent top end Yamaha plugins. Excellent for guitars, vocals .. you name it. Proper metal cases as well.
http://www.steinberg.net/en/products/audio_interfaces/ur_serie/modelle/ur44.html
http://www.steinberg.net/en/products/audio_interfaces/ur_serie/modelle/ur22.html
The L'Oreal anti wrinkle ballbag cream, I am worth it, but it looks like it's going to take vats of the stuff to make a real difference
My YouTube Channel
Feedback
