Ohms question (head and two cabinets)
I have a head with 4, 8 and 16ohm options.  It has a 'main' (use first) output and an extension output.
 I have two 8 ohm cabinets.  Both have two sockets.  One has no specific labelling, just two sockets; the other has two sockets, one for the head, one presumably to connect to a speaker.
I've set it up with cables from the main and extension on 4ohms.  Is that correct?  And how do you connect the speakers up using just one output?
Thanks!
Trading feedback info here
My band, Red For Dissent
  • Paul_CPaul_C Frets: 7922
    "Usually" (because I don't know for sure how your stuff is wired up) you run a speaker cable from amp to cab #1 and a second from cab #1 to cab #2 and set the amp to 4 ohms.
