Any advice from those in the know would be welcome please.
I've been using an old Korg D1600 to record at home, and recently tried mixing tracks exported from the D1600 in Reaper, which I liked, so thinking of trying to move over to just recording into laptop, taking advantage of midi etc.
I've got a macbook pro which is several years old - 2.4ghz core 2 duo, 4gb, and am thinking of getting something like one of the focusrite usb interfaces. Is that setup likely to work ok for Reaper, recording audio and midi up to 16 track, maybe running the odd vsti?
Anything else I need to think about before spending any money?
Cheers
https://twitter.com/spark240
Reddit r/newmusicreview
I am typing this on an HP I3 laptop which in in fact also a 2.4G 3 core CPU, originally with 4G ram but upped to 8G (cos I could, does not seem to have made a lot of diff!)
This will easily run the demo tracks in Reaper and Cubase LE6 so that MacBook should be ok.
You mention MIDI ? So don't get the bog S 2i2. Starter kit would be the 2i4 but the UR22 is cheaper, has MIDI and comes with Cubase which is top bollocks for MIDI work.
But for maximum flexibility, lowest latency and stone solid driver, checkout the Native Instruments Komplete Audio 6. Another 40-60 quid or so but I promise you won't regret it.
Dave.
Didn't know you could swap bits out of macs?
How do you re-install the OS on a new drive?
Dave.
Ok, just that I heard tales of soldered in ram!
Dave.
Pretty sure you can direct monitor 3/4 on headphones as there is a 1/2-3/4 button but no, can't see how you would assign 3/4 to line outs 1/2 to speakers!
There would be a delay but only a very tiny one with ASIO drivers because the KA6 is noted for very low latency. In any case, you would need some form of monitor switching? Can you explain the exact scenario you wish to set up and I will try to duplicate it here.
Jusfort! I also have a Focustite 8i6 and you can download Scarlet MixControl software for that and other F'rite AIs . Looks bloody complicated but I dare say it would be possible to set up all kinds of custom routings...but who has the time!! Being an old TV/amp valve jockey I tend to go for hardware solutions!
Dave.
Dave.
