Tone control wrong way around on 1st build Jazzmaster
Hi,
Over Xmas I did my first build. A Jazzmaster type guitar from Gear4Music. Everything is fine apart from 1 thing: on the 1 and only tone knob, the trebly is where the bass should be and vice versa. Have I wired something wrong. The guitar is perfect apart from that. maybe Jazzmasters are like this, I don't know? Any help would be greatly appreciated as I know there are far more knowledgable people on here than me.
Thanks in advance.
  • Andyjr1515Andyjr1515 Frets: 3129
    edited February 2015
    Hi Paul. Sounds like one of you wires is soldered to the wrong tag on the pot. Looking down into the control chamber with the prongs pointing upwards, the hot wire from the volume pot should be attached to the left prong.
  • ICBMICBM Frets: 74503
    That depends on which way you're looking at it :).
    It should look like this, as you look at the pot from inside the guitar:
    It doesn't actually matter which of 2 and 3 is connected to the cap, or whether the cap goes to ground or the volume control with the other terminal grounded - all will work. What's important is to use terminals 2 and 3.
    Sorry, @ICBM ..... When I said prongs pointing upwards, I was forgetting that they are actually pointing upwards too. I should have said outwards/upwards from the pot disc. A picture would have been clearer, especially with me coming from Wolverhampton and all :)) Your picture illustrates nicely :)
  • Thanks Andy, you come to the rescue yet again! Is there anything you can't do? LOL Thank you so much. I'll strip the strings off sometime this week and swap the wires. Much appreciated.
    Yeah - I can't sing.   But to every-bodies' horror, I try.... ;)
    ...and when it comes to most things electrical, model identification, refurb, and repair, I'm not even in the same league as @ICBM!
  • Oh How rude of me. I thought all the replies were from Andy. Thank you very much for the diagram @ICBM. Hope you don't think me rude. Apologies. Much, much appreciated.
    It's not even my diagram, I just found it online :).
