So I went to change pick up rings on my les Paul this weekend but having only removed the neck I found out it didn't fit. I replaced the pick up as it was but now my neck pick up is booming and much louder than the bridge. I don't think it was like this before.
Am I right in thinking I must have altered the pick up height and that's what's making the neck so much louder?
Also why is it some nights you put your amp on and plug into your board and its tonal bliss and others its a case where no matter what you do it's not just right? I do wish I could find a one guitar straight into an amp set up that just works.
I think by the end of the year I shall aim to have a two amp set up that is one clean and one drive. Or maybe one amp that is a great drive but cleans up nicely with the volume?
Tonight has been a tonal pain in the butt.
As for tonal variation, it proves to me how fickle our ears are. It probably sounds much the same, but your mood can affect how you hear things I reckon. If you were already frustrated at the neck pickup behaving weird, maybe you have perceived everything differently.
I am sure it is all in the mind because nothing has changed since last night. I'm the only variable.
I shall lower the pickup. Do you find that you get better clarity when the pickups are lower?
As a great guitar player once said.*
* actually that was Kevin Costner in the golf movie Tin Cup but it's true.
Plus as the wise man said above, our mood makes a big difference to our appreciation of sound. Also taste, smell, sight, even sex )
Sometimes our ears need a datum to calibrate to, trying to make an electric guitar sound great in isolation is largely pointless anyway IMO.
