http://s28.postimg.org/jzt83mpbw/IMG_20150224_021911418.jpgI've attempted to draw a diagram of what I've wired so far, there is a momentary killswitch on the volume pot and the Tone is going to be a Push/Push coil tap or split. (Which would you advise)
I've gone as far as my knowledge will allow me, and tried to work as much out as I can. will happily redo most of it if it's wrong. I am up doing it at 2:30am ffs!
Please tell me if the diagram is indecipherable, and I'll take pictures of the control cavity. I've *tried* to keep my wiring tidy so far, so it might be easier to see...
'Awibble'
Get it working without the split or kill switch first
Instagram
Instagram
This diagram should cover everything but the kill switch
http://www.guitarelectronics.com/product/WD2HH3T11_01/Guitar-Wiring-Diagram-2-Humbuckers3-Way-Toggle-Switch1-Volume0Tone001.html
then add this after you have the rest working - but you can wire it to the volume control like you have shown above, as long as the switch connects the live signal to the ground it will work
https://www.premierguitar.com/ext/resources/archives/312935c1-7b27-497d-aba8-39a67d6d5bc5.JPG
Instagram
