Walk into room pick up guitar, press one button on the tuner, strum slowly and its in tune.
As opposed to
Walk into room, pick up guitar, strum, pluck string, tune string, pluck string again, tune a bit more, compare to next string, repeat five times.
It doesn't take long, agreed, but the other system is more accurate than my ears and just so damn quick and convenient.
And once you master it, open tunings and custom tuning are about four button pushes and a strum away, with going back to standard two button pushes away again.
It isn't 100% accurate but the luthier I spoke to this morning who had fitted one for a client remarked that 99 per cent of the time it was 99% accurate.
Thats interesting. It doesn't really tally up with Gibsons other "innovation" on these the 2015 models - the adjustable nut to allow for a greater range on setups, paired with tuenrs which allow less???
anyway, I have nothing against automatic tuning mechanisms, but they always come with a compromise.
The evertune is brilliant, but it needs to be set-up right to feel normal. bending is a compromise, but you can set up exactly how much of a compromise it is. i.e. you can set it so bends are nearly impossible, or that they only engage after you push a certain distance. If you set it so bends are totally normal then you loose the benefits of the system. You can change this relatively quickly just using the tuning pegs, they no longer affect tuning within a certain range. that is still 6+ things to adjust to change the way it plays
http://www.evertune.com/Bending/
for me it simply comes down to having too many moving parts - i like simplicity. Would love to have chance to install and set-up one though,I have only had a quick play. its on my list of fancy bridges to use at some point
Instagram
its a great feature really, you can set exactly how much tuning variance you will accept. I just wish it was easier to turn it off and on
thankfully evertune are quite open about all this
They also offended my sensibilities by installing one on a vintage 335 as part of one of their early endorsements.
Instagram
Nil Satis Nisi Optimum
