Alternatively, Mojo do wiring kits.
I had a tele one for an xmas prezzie, and although it took me a good few weeks to do it was well worth doing.
If you just want to change pickups and have a go at painting over an existing finish then consider buying a Harley Benton Tele and join in the modding challenge.
Be aware that vintage style ashtray bridges are often not a simple swap due to the pickup routing position and screw holes/ferrule holes.String height adjustment can be an issue.
Neck pockets vary in width as well. If starting with a new body I'd suggest (as others have already) to go with one from Guitarbuild and a neck from Northwest guitars.Both are Fender dimensions .Cheaper necks are available but make sure they fit the neck pocket (eg. Harley Benton neck 57mm width-Fender/Guitarbuild 56mm).
Kits are a great idea.
I'd be interested to know what you decide.
Graham.
