My music:- https://soundcloud.com/hubobulous
If you plug into a lower end modelling amp and try to work levels from the guitar volume you tend to get less amp response and more just louder- quieter versions of the same sound and that's easy to spot the same two sounds don't always work for the different tasks.
Even for clean playing it's rarely two volume levels of exactly the same tone. Turning the guitar volume down a bit softens the guitar tone so you have more bite when you turn up; you may even find that a clean solo tone isn't actually 100% clean if you whack a chord through it.
Dependant on how much gain you have before the solo there's a few options.
1. O/D pedal for a gain/volume boost, works well for a low-medium gain situation. Less so for high-gain. Too much gain can cause compression, limiting the volume gain, and "squashing" the sound.
2. Clean boost for a volume boost. Works well post gain* as purely a volume boost.
As has been said having something with a mids boost cuts best.
*deliberate, as the gain can be from a pedal or from the amp.
