your main issue will be mounting the bridge. there is a good chance a stud mounted tailpiece would pull out of something as soft as cedar. try to use longer studs that go through it, or use a different style of tailpiece to take the pressure away
it will also dent pretty easily - a harder finish may be more suitable. you have used wudtone so can make up your own mind on whether its going to be tough enough for you on this. tbh a finish that wears easily may suit the guitar
where is the red cedar from? if it was intended for acoustic tops then it should have a high grain count and be quite stiff and a bit harder. if it was intended for fence panels then choose a bit more carefully
Instagram
Mind you, if you are capping it you can always add chambers to compensate...
