Help a stranger in a strange land please
DaleftyDalefty Frets: 509
edited May 2015 in Making & Modding
This was just a waste of my time and effort.
DaLefty
Both dog and owner available for stud, please contact DaLefty if interested
  • bandmaster188bandmaster188 Frets: 391
    edited March 2015
    hello and welcome to the forum.
    there is a pretty broad selection of bits and bobs right here that will help, and some good explanations about the different types and values of pots.   http://www.axesrus.co.uk/Electronics-s/1827.htm
    you'll probably be needing 500k for volume and tone if you are going for humbuckers.
    The Swamp City Shakers
  • DaleftyDalefty Frets: 509
    edited May 2015
    DaLefty
    edited May 2015
    DaLefty
    edited March 2015
    i'm no expert on this and a lot is down to personal taste. cts pots used to be the favourite but some folks are going for the more expensive bourns pots. i've just bought a pair of the alpha long shaft push pulls as they seemed to be the only available type in a long shaft. the cap debate is a long and painfull one and i'm not going there. i've used the orange drops which are good and i've just bought a bag of these cos they were cheap and don't really know if they are any good or not but i'll find out soon.  http://www.ebay.co.uk/itm/261395486673?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    switchcraft switches and jacks are the best.
  • its worth reading the info on the type of pots you want ie linear or log all of which is well explained here.
  • TTonyTTony Frets: 27692
    Re the pickups.
    Save yourself 50% or more off the cost with no compromise on the sound quality, and get a set of Oil Citys.
  • Adam_MDAdam_MD Frets: 3420
    TTony;545389" said:
    Re the pickups.
    +1
  • ChéChé Frets: 305
    Gibson SG's have the front strap button mounted on the back so they can be easily flipped to play left handed.
    Case in point...
  • randomhandclapsrandomhandclaps Frets: 20521
    edited March 2015
    Dalefty said:
    If it helps, here are the guitarists sounds I am into and sounds I am trying to emulate and combine:
    Randy Rhodes
    Slash
    Muddy Waters
    Zack Wylde
    Joe Perry
    Angus Young
    Tony Iommi
    Eric Clapton
    B.B. King
    Unfortunately they are all right handed players so your mission is doomed.
    I echo the above regarding pickups.  With regards to all your other parts, provided you don't mind waiting a week for delivery Banzai music and Musikding have a good selection and are well priced.
  • WezVWezV Frets: 16790
    Case in point...
    If only the bridge wasn't angled for intonation that would work fine.
    Just because. Jimi did it don't make it right :)
  • steamabacussteamabacus Frets: 1268
    First of all, relearning how to play 'the wrong way round' must be very daunting - you have my respect for even attempting it.
    Regarding pots, you might want to have a read of this thread about anti-log pots. As a righty-turned-lefty you are in a pretty unique position - it will be interesting whether right-handed or left-handed pots feel 'right' now you've flipped over.
    edited May 2015
    DaLefty
  • ToneControlToneControl Frets: 11975
    phone the pickup manufacturer to ask what pots are best
    btw, while you're learning - would you be able to learn right-handed lap steel? this would allow you to use your existing right hand technique
    edited May 2015
    DaLefty
  • ICBMICBM Frets: 72646
    The pots could be a real issue - do you use them a lot? And do you want them to turn 'right handed' or 'left handed'? This isn't a trivial question and depends on whether you normally *turn* the knob (in which case right-handed "clockwise for loud/bright" motion should be fine) or *roll* it with the side of your hand (in which case you will probably need left-handed "up for loud/bright" motion is better).
    If you don't use the pots much, it probably doesn't matter what you use, but if you do use tham and want "left handed motion", standard Log pots will not work correctly. You will need either "reverse Log" or at worst, Linear - which won't work as well, but at least not as badly as normal Log pots wired backwards.
    Whatever pots you choose, try to get large-diameter high-quality ones - they just work better. It's also worth replacing the jack with a Switchcraft, since far-east ones are universally crap. Don't waste money on caps though - anything of the right value will work just as well as any other, despite popular myth which says otherwise.
    Unfortunately it's going to be *very* difficult to find high-quality, reverse-taper pots with push-pull switches for the coil splitting.
    Have you come across Helen Reeves, by the way? You have something in common… she was also forced to switch to playing lefty.
  • You could try one of these switches if the push/ pulls are a no no. http://www.axesrus.co.uk/NSF-Freeway-6-position-switch-p/nsf3x3-03.htm
    edited May 2015
    DaLefty
  • FelineGuitarsFelineGuitars Frets: 11636
    You will have more choices and better  contours on right handed pots
    Choices of lefty pots are limited and almost non existent on push pull varieties
    What are you doing with real Ivory and real Tortoise shell picks?
