I'm still trying to persuade someone on here to spend a fortune on importing a DV Mark Guitar Tube Marker which is a jazz-blues oriented pedal but I suspect you would be better off with something with speaker emulation, using the AER like a mini PA. So, +1 to @ICBM really.
[edit] I forgot to mention, I also have an Xotic AC+ Booster which stacks really well into the JD-10 for a kind of 'Tubescreamer into cooking amp' setup.
Scofield uses a rat. But he uses normal tube guitar amps so not the same as your situation.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
I use a Joyo American sound into my AER Compact 60 when noodling at home .
Works well and sounds great .
