Mac mini info please
spark240spark240 Frets: 2090
Im now leaning towards a Mac mini for recording with Presonus Studio 1, they seem to have all the right attributes but.....
There seems to be a tendency to go for the older 2011 / 2012 models and Im not quite sure why...maybe because they are more upgrade-able or the processors are apparently better then the new models.
Any clues?
Mac Mini M1
Presonus Studio One V5
 https://twitter.com/spark240
Reddit r/newmusicreview
    Will you wanting to upgrade it?  The older one was easier to upgrade because of easier access on the bottom.  The newer ones have their RAM soldered on and you need to decide when you buy it how much RAM you need and you are stuck with this.
  • spark240spark240 Frets: 2090
    As long as I have at least 8G Ram Im not too fussed.
    Mac Mini M1
  • kinkin Frets: 1015
    sorry if this is a stupid question as I'm not very tech minded.
    I've had a lot of fun using the iPad for recording into garageband, but I have started to find it a bit limiting.
     So, I downloaded Auria on my ipad2 and am getting lots of low memory, too much cpu thingy messages, resetting it seems to have helped, I may need some extra power though.
    I had been thinking of going for the iPad air 2, my question is, would the mac mini be a better bet?
     I don't need a pro set up just something that would allow me to build up lots of tracks and have more control and more powerful apps and plugins.
  • Axe_meisterAxe_meister Frets: 4654
    The problem with the new max mini's
    A) non upgradeable, both memory and very limited on disk.
    B) Although the cheapest Mac mini is £100 less than the old cheapest Mac mini, the equivalent to the old one (4 core) is now £100 more.
    For the Mac mini to be of any use in a few years time you should get the 4 core, 8 GB memory with either SSD or fusion drive. The 500GB spinning rust drive is as slow as hell.
    edited March 2015
    That's the info I was after...thanks, I assume actual hard drive size is not important as I can use an external ?
    Mac Mini M1
  • TeetonetalTeetonetal Frets: 7815
    Yes - I have a 2012 i7 Mac Mini that I bought in Dec 2014:
    Why
    Comes with Mavericks (check your HW interfaces etc are combatible with Yosemite before upgrading .- mine aren't)
    2012 i7 Ram is up-gradable to 16 GB 2014 versions are not. (ram is soldered to the board.)
    2012 i7 is quad core, 2014 i7 is dual core. Quad is better for music
    2012 mini takes a SSD or 2nd HDD if you really want - new one doesn't (to my knowledge
    2012 was 50% off - new one isn't
    2012 i7 isa actually a better performer for music than the 2014 i7.
    2012 still has firewire (was good for me)
    Enough reasons?
    Why
    Enough reasons?
    Enough reasons.....I want one !
    Mac Mini M1
