I'm looking for an amp that will be for home use only. I have had loads of boutique stuff in the past, but this is usually expensive and need pedals / attenuators etc to achieve an acceptable tone.
Anyone here run a THR amp? it looks perfect for plugging headphones into and rackin away in private. But how do they compare to a Fender Mustang or other such modelling amps?
As others have said, it doesn't have a lot of gain, but I've found running a pedal into it works well. I have heard you can squeeze a bit more gain by using the compressor, which is only available via the PC, not the onboard controls. I need to get around to playing with that.
JM build | Pedalboard plans
