In the process of converting an extraordinarily nice fender am deluxe strat into a more vintage style strat, I have got new (true single coil-not hum cancelling) pickups, new non fancy wiring (no S1 switch), and some plastics to make everything match.
Three packages here, one from a lot earlier, I have a set of oil city staggered triple blues, very fast winding/delivery, great service too, can't wait to wire them in!
Also won some
wooden plectrums to shape/make from crimson guitars that look a lot nicer than I thought they would, will update on how they play when I get a chance.
Then the others are a delivery from thomann;
Montreux wiring kit with custom cts pots, crl switch, switchcraft jack and loads of other goodies, not much about these online but they come with very nice vintage cloth wire, solder, and even a colour wiring diagram.
I'm not a McDonalds burger. It is MkJackary, not Mc'Jackary... It's Em Kay Jackary. Mkay?
I know, I can't believe strats came wired without a bridge tone, if anything that is the pickup that needs it most.
The original idea was to give three preset tones, with the bridge pickup being the always-trebly lead sound, the middle for normal rhythm playing and the neck for bassy sounds, so it makes sense if you use it like that. I played in a couple of 50s-style rock'n'roll bands and it really is what you want. The concept of the neck pickup for lead and the bridge for crunchy overdriven sounds hadn't occurred then.
I really like this wiring because you can have mildly rolled off neck and other tones but if you want to switch to the bridge you can have it on full, or the other way round, if I was using that as a warmer rhythm and the neck/middle as a lead
Also, the reason the second tone didn't work was because I wrapped one of the wires round the terminal, but mist have forgotten to solder it! And there I was thinking I might need to replace a burnt out potentiometer.
