Hello, noob here (although I use to post on other forums and have been lurking for a bit). Ive been borrowing my mates Hardwire overdrive for a while and have been really impressed at how it pushes my dirty amp into chunkyness. I really like the dual EQ and the extra tweaking that it gives you over a normal tubescreamer. He wants it back soon so I want to buy one for myself but was wondering what else is similar as I want to check out a few alternatives first. I really want something which can do the similar low gain tubescreamer type drive but with the dual EQ for more tone shaping. I'll be using it to tighten up a high gain head or push a medium gain amp. Cheers....
The CM-2 is a favourite of mine.
Alternatives,
EHX East River drive, essentially a tube screamer by a different maker.
Boss SD-1 or DS-1 pretty much a "go-to" pedals for a lot of guitarists in a lot of genres.
Digitech Bad Monkey a cheap TS-alike pedal with treble/bass adjustments. Again a favourite.
Digitech Hothead pretty much a DS-1 with bass/treble controls rather than mids like the DS-1.
Hardwire SC-2 tube distortion, similar to the CM-2, but gain is a bit higher.
Marshall Guvnor (MK1) sounds almost identical to the CM-2.
Marshall Jackhammer, Guvnor2, Drivemaster, Shredmaster all pretty much "Marshall in a box" type drives.
pretty much with monquixote, if you know you liked the hardwire it's cheap enough that it's probably the thing to get.
