12 AX 7.
SassafrasSassafras Frets: 30320
Do preamp valves need to be warmed up? I ask because I've got a buffer that uses a 12ax7 and don't want to damage it. Obviously I know nothing about the technical side of valves otherwise I wouldn't be asking.
  • ecc83ecc83 Frets: 1649
    Well, the beardy/tweaky/audiophools might say so but in reality no.
    It is actually almost impossible to damage a preamp valve electrically in  conventional circuit, even excess heater volts will be withstood for quite some time. In fact, switches and jacks are likely to fail before a good old ECCXX!
    Dave.
  • SassafrasSassafras Frets: 30320
    Thanks for setting my mind at rest.
