DaLefty
Grover 305 series mini rotomatics I believe... 18:1 ratio
You are right, this is a strong suggestion that I shouldnt do it ho are you getting along with the ML by the way?
With enough coats the green should hold... I'm anticipating 5-6 coats of paint for this peavey! I've sanded everything down to wood front and back, and mostly off the sides. I just need to hand sand the really curvy bits and do some reshaping. Then I have to pick what colour this thing is gonna be...
http://www.axesrus.co.uk/ProductDetails.asp?ProductCode=10060220&CartID=1
DaLefty
DaLefty
I don't use them on everything, but when I do its for easier string changes.
If its not the trem bridge you are adding then it is a lot easier, but also more pointless and still likely to change the guitar in unpredictable ways
Instagram
