I'm on another Neil Young binge and after playing about with my Pro Jr for the past fortnight I wound up using the controls on the amp to vary the amount of distortion/brightness
in lieu of a whizzer! I've never really used an amp for anything more than a clean slate for pedals and I found it so much more rewarding and intuitive than any fuzz/overdrive pedal.
Which got me thinking... would it be possible to build a 5E3 clone but have two sets of controls (or more?) that you could switch between with a footswitch like channel switching, while still retaining the traditional controls like the 4 inputs (which you could then theoretically use a line selector to switch between as well) and more importantly, the interactive volume controls. Maybe add a VVR control for the times you can't crank the amp naturally, maybe even have one per each set of controls... that way you can really balance the volumes of the different settings.
I'm guessing there's a reason as to why this couldn't work and hasn't been done before? If so, besides motorized pots and all the complications that involves what other options would there be?
(a nice pic for the thread....)
http://i232.photobucket.com/albums/ee301/snotmale/Things that make you go Ding/Deluxe_57_top.jpg
Basically a multi channel amp where all the channels are the same.
You could also have a Power Scaling set up which has a pot for each 'channel' and switches between them when the channel is activated.
