So
@fiftyshadesofjay s timefactor arrived yesterday. Initial impressions, comparing it against an RE 20 and delaylab which are soon to take a trip to the classifieds :
It has a really great basic sound as you would hope. Really nice hi fi pinginess on the digital mode with the filter for less pinginess as you desire.
I like the fact that it's a true dual delay so I can get faux delay + reverb sounds like on the re20 by setting the second delay to a slapback.
Multi tap is a standout for faux reverb sounds.
I nailed a couple tones I want I've previously only gotten via VSTs.
It's small! Or at least a reasonable size compared to the delaylab which is a monster.
A couple downsides:
I think I really need an external tap as I can't be dealing with the hold to get to play mode thing.
The mode switcher knob seems to sometimes control a different function to switching modes and I can't find in the manual the logic behind why.
The self oscillation isn't as great as some pedals. The RE 20 has wonderful tapey self oscillation but the time factor reveals itself as a digital pedal quickly when you start turning the delay time. In fact I'd say the re20 might even have a better tape sound full stop.
and I've modded another momentary switch with a resistor to ape an expression pedal at full toe down. I'm hoping to use this to have a kill switch, and mess around with settings in a fun way... momentarily remove one of the delays or the modulation... or ramp up the leslie sound to fast...
