My Laney LC15R has the following symptoms:
1 Harsh grainy nasty distortion even when set to very low gain
2 Gain level and master volume work as expected except nasty distortion present at all volumes, but overall output of the amp is much quieter than normal
3 Nasty distortion generates very obvious 'out of tune' overtones on most individual notes
4 Nasty distortion on both hi and lo inputs.
5 With no lead and gain and vol on max there is a bit of noise but nothing more than you'd expect on a cheap valve amp.
I have another faultless LC15 (not the R) so diagnosis carried out so far includes comparison between both amps having swapped guitars, cables, speakers, and all valves. Also compared all voltages - problem amp is running approx 10% higher voltages at all points measured so far.
Tried measuring voltages on coupling caps to see if any leaky DC getting through but nothing detected on output side of the caps. Electrolytics have the usual silicon goo on them but otherwise no visible problem. No obvious scorching or deterioration on any components.
Just about to bridge out the LC15R reverb and FX loop PCB to exclude that from equation but wonder if any amp gurus had any advice?
If the bad one is much quieter and/or still sounds bad, the problem is in the power stage. If they're the same it's in the preamp.
Forgot to say that the contra of third amp send into the FX Return of the LC15R still had nasty distortion.
Ah the schematic puts me into solid state territory so any further differential diagnosis you can advise will be much appreciated.
The reverb is most likely the tank if it's the older spring version.
