Wiring help please....
Electronicicity types....
I want to put a flourescent tube light and seperate pull switch in my shed.   I have two 13 amp sockets out there already - what do I need to do to achieve this (apart from pay an electrician, of course).?
  • ICBMICBM Frets: 73076
    edited October 2013
    A 5A fused isolator box, the pull switch, the light and some cable.
    You're not supposed to connect lighting directly to a ring main or a spur since the fuse at the distributor box is too high a rating to protect it, so you need the isolator.
  • RobDaviesRobDavies Frets: 3090
    Cool - thanks.  What does a 5A isolator look like?
  • bertiebertie Frets: 13578
    google and screwfix is your friend
    ...ish.
    When you search for 5a fused isolator box in Screwfix, you get this:
    http://www.screwfix.com/p/wylex-sfcfl05-5a-cartridge-fuse/63771?_requestid=133574
    Is what I need actually a small consumer unit?
    edited October 2013
    yep   with a 5a  trip cartridge
    Thanks.
    They look complicated.  I'll use a table lamp for now and save up for a sparky to come round.
    You don't need a consumer unit, you're just taking a feed off an existing ring main (or spur). I can't get the links to work from my phone for some reason, but just do a Google image search for 'fused isolator' and it's the first thing that comes up. You should be able to get one from any DIY shop.
  • FX_MunkeeFX_Munkee Frets: 2491
    Try searching for "isolator switch" or "5A FCU" that should get you what you need.
    Shot through the heart, and you’re to blame, you give love a bad name. Not to mention archery tuition.
    not if there's one already feeding the two 13a sockets (which admitidly I didnt read originally)
    If there isnt, Id want a breaker between the shed and the "house mains"
    Got it.
    So I just need to put a 5A fuse in one of these:
  • IanpdqIanpdq Frets: 131
    edited October 2013
    It's called a switched fused spur with a 5 amp fuse in it run a 2.5 cable from the socket to the spur and a  1mill cable to the light and that will do you the connections are marked live and load  being a sparky I should know don't forget your earth sleving  :)
    Thanks fellas.
    I think we got there in the end.
    I'll be buying the bits today......
