SOLD: Rothwell Stompjuice pedal power supply
This is a Rothwell 9V 600mA DC power supply.
It has an internal switch to change from 230V to 115V for the input mains voltage. It's set to 230V at the moment. It has 6 2.1mm DC parallel centre-negative output connectors which can handle a maximum of 600mA. The majority of analog pedals pull less than 50mA but digital delays and reverbs can draw in excess of 100mA each. Just make sure you know how much juice you're pulling. It has internal fuses and comes with a spare all housed inside the sturdy unit.
This has been replaced by a Voodoo Labs unit as I needed more sockets and flexibility.
There are a couple of scratches on one side of the housing and it's missing one of the small rubber feet. It's built like a tank so should be able to handle anything you chuck at it excluding beer or wee.
It comes with the original paperwork and box. It does not come with the mains lead or any of the connector cables.
Price £59.10 posted. If you can pick it up, I'll knock the £4.10 for postage off.
Do ursus deposit feculence in the thicket?
Here endeth the lesson.
