I can't comment on the current draw without testing one. You can do this yourself with a decent multimeter quite easily. Google is your friend...
As for a 'noisy' power supply from Line6... That's not right. Those things are normally bullet proof and quiet - I have one that used to sit under my desk until Line6 UK closed. It was sat there for 10 years plugged in without even getting that warm - when the unit it's powering is switched off, the Psu is still chuntering away.
There have been suggestions of the Voodoo Labs unit - this was the only aftermarket power supply that we found would reliably work with Line6 gear and was the only one we used to be allowed to even mention when talking to customers about tech support.
Hope that helps
About 3/4 the way down..
http://www.thegearpage.net/board/archive/index.php/t-850784.html
