I use a tweed 5f6a clone in a head, Ceriatone kit, but professionally made. I'm using it with a Zilla 2x12, modern I think with a Marshall branded V30 and a G12h30. It sounds great but I find once it is turned up to gig level, around 5, it seems a little boomy and harsh, even with bass turned right down. I use a Liquid Sunshine and a compressor in front of it.
Just wondered if anything obvious in the setup, namely speakers might be causing this, or it's just a characteristic of the circuit. Was thinking of trying with 2 vintage 30s instead, does anyone recon that would make a difference, or any other suggestions?
Thanks for reading.
Are you using the bright input only? Avoid the normal channel (jumpering the 2 will make it worse) and keep the normal volume down, as it still affects the sound, even when not in use.
Your cab doesn't seem like it would cause any issues.
It's quite an easy circuit to tweak for less bass if all else fails. The quickest way is to change the 1st stage cathode bypass cap. Going to around 10uF is a good starting point and tightens things up just enough IMO.
Bandcamp
Spotify, Apple et al
Much better really. Similar core tonality but when wound up the v30 mids are more prominent and the g12 bass less do.
But that's you.
I have, although I would generally adjust it slightly higher (which is why I said 'at or around').
Excessive boomy bass on JTM/5F6s is something I've come across a lot, and have done the mod a fair few times. However, I sometimes get asked to mod amps, and find that the owner has got all the EQ at 12 o'clock and expects the sound to be correct at that point. This amp being a bass amp may not run best at that, and I've found that being fairly brutal with the bass control, particularly when you have the amp cranked for crunch works well.
It is a bass amp after all.
I'd also dial the mids and treble well up too.
I take back what I said about turning the bass up if you're actually using the normal channel, it didn't occur to me that you would be . It will be fine - you barely notice a 3dB difference when the speakers sound different.
The one in my friend's cab sounds the same volume as the Classic Lead (99dB) he has in it, which doesn't sound any quieter than the V30 did.
