Even if they only last a couple of uses, which is all I think I will need them for, I could replace them 45 times for the cost of a crimson version, although granted that wouldn't be very green.
It is however very unlikely that I will own that many guitars, purely because the divorce costs would bleed the GAS fund dry.
Like:
http://www.ebay.co.uk/itm/like/170861286704?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&chn=ps&device=c&rlsatarget=&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0-L&ff12=67&ff13=80&ff14=108&ff19=0
or:
http://www.ac-one.co.uk/swp-nozzle-cleaners-12209-p.asp?gclid=CM7j6eqMosUCFWvMtAodaWQA2w
They are extremely cheap and work wonders on synthetic material and plastics, however they are rubbish on bone and ivory.
I would avoid the Stewmac ones like a $2.00 whore with syphilis, they are over priced cheap and shitty and will far apart if they don't wear out first, and we are talking about failing in weeks, not months.
DaLefty
I never ceases to amaze me how such a little change at the nut effects playability. (For the better)
While they did I the job, the b and e strings were a little slow as the metal file for these is like a guitar string and a little flimsy. I certainly wouldn't look forward to doing them again Any time soon.
I now see the worth in a proper set of files, whether I justify spending £89 on a Crimson set is another matter.
http://www.thomann.de/gb/ibanez_4449ep1_rasp_set.htm
Edit - Can only find 6 file sets now. Crafty of them to make you buy more than one set!
Just for balance.
I use some of the stew-mac double sided nut files and have had the same set for over 10 years. They have been used on a minimum of 1 guitar a week in that time.
One of them snapped when i used it to open a tin, but it still has most of its length and is still usable. They all still cut absolutely fine
Instagram
