Eqd Speaker Cranker clone
Barber have several flavours of double-dirt pedals. There's a German(?) company called Rodenberg who make several double-dirt pedals with some cool switching options.
The one I use is the Foxrox ZIM- two truly independent channels (many "dual" drive pedals are really one dirt pedal with a built in boost that you can only use with the main drive engaged) with switching jacks on the back so you can run the two channels effectively as two pedals- they don't have to be adjacent in your signal chain and they don't have to be guitar -> Ch.A -> Ch.B -> amp. Ch.B also has a very interesting EQ section that uses phase cancellation to thicken or er... thin-en your tone.
They also have a facility for you to swap the circuit boards inside the pedal to set them up as different types of dirt pedals- several tubescreamer variants, Si Fuzz Face, Big Muff and Octavia cards, a distortion that's meant to be somewhere in the RAT / Distortion+ ballpark, a transparent clean boost and a couple of less TS-like low/mid gain ODs. The pedal isn't cheap but the ZIMcards are, and the ones I have ("boutique" TS, low-gain OD and Fuzz Face) are all very good at what they do IMO.
