If it is, and the PT is robust, and you're lucky, it will just have blown the primary fuse. If not you've blown the PT, most likely.
If it's not a voltage selector, it's either an odd coincidence or the mid boost caused a power valve to fail which has blown the fuse, or something similar.
Here's the fuse.
The best person to speak to is Jesse, his customer service is second to none, even on amps bought s/h. He once did a one hour Skype session with me while I re-wired a modded Lazy J back to stock!
(formerly miserneil)
He is brilliant at responding to things.
Buy with utter confidence.
So yeah, it has an voltage selector as well as the mid boost toggle, mentioned when I delivered you the amp
Hope it's not too bad mate, glad that Jesse looking into that for you.
Yeah all good- don't worry!
We could have a whip round and pick you up a used Marshall MG10 if that would help
Eqd Speaker Cranker clone
