Ageing new plastic for a relic tele? Help... Tips pleas
stuagustuagu Frets: 334
edited May 2015 in Guitar
so I've got a brand new black scratchplate goin on a tele. I need to age or get it aged. Any tips for havin a go myself? Or is there someone on here that can sort it for me? I don't just wanna go at it with some wire wool and then it just looks like some has just gone at the plastic with wire wool rather than old/ used. Thanx in advance Gu :)
  • jd0272jd0272 Frets: 3867
    Is it 'plastic' or proper Bakelite? Spray a few costs of clear cellulose on it, leave it for a week, then wire wool it where you want it 'fettled'.
  • maltingsaudiomaltingsaudio Frets: 3186
    Rub with used Tea bags to dull it
    www.maltingsaudio.co.uk
  • stuagustuagu Frets: 334
    edited May 2015
    I think it's plastic rather than Bakelite although it look "right" if that makes sense. And it's black if that makes a difference. :)
  • streethawkstreethawk Frets: 1635
    I'm starting a bakelite Esquire one today (time permitting).
    Need a motor for my buffer so could take a while.
    :-S
  • 57Deluxe57Deluxe Frets: 7362
    1200 w&dry with w-up liq...
    If it was white, apparently soaking in coffee suds does a job
    <Vintage BOSS Upgrades>
    Thnx guys... Il give it a go and report back how rubbish i iv done !!! :)
    Lacquer the pickguard... let it dry for a few days..... start wet sanding, with 600 - 800 grit.... applying slightly more pressure where you want the wear-through don't worry about the shape of the spot, everyone's wear's differently. Once you begin to see the underlying pickguard, proceed slowly at the wear target... stop with the wet sanding when it looks right.. and polish, yer dun...
    Ron Kirn
    Bit more detail from Ron Kirn over at TPDRI.
    Thnx Mr hawk
    Well I started, then forgot, about my prototype.
    Pic a bit cloudy....
    Need to level the orange peel around the string path because that area is staying quite shiny.
    Top half needs some work too, bottom half nearly done.
